Encore's avatar
Encore
Leaking Bottle
I have a radiator coolant surge bottle which is made of some type plastic. There is a brass fitting which screws into the top with a small tube connected to it with a clamp. The brass fitting has a small leak around the threads when the tank is hot and pressurized. I removed the fitting and put the white tape on the treads, but the leak persists. Is there a better method/sealant to seal this fitting?
  • Thanks IAMICHABOD. I will try it.
    This tank I bought 16 months ago cost $200 PLUS fast shipping from Oregon another $100... so, I'll try anything at this point.
  • The tank is only 1 year old and I don't believe it is cracked. In fact the reason I reseated the fitting was because it was too loose. Since the tape did not work, I thought there may be a gasket sealant. Maybe JB Weld or something I could use instead of tape.
  • Yes, replace the surge bottle, the plastic probably has a lot of minor cracks in it from the heat.
    On my 2005 Fleetwood Excursion 39S with a Cat C7, the surge tank that sits on the top right corner of the of the radiator went in Billings Montanna last year. Luckily it was across the freeway from a Freightliner dealer. They had them in stock because a lot of them went out. They said the original plastic wasn't a good quality for the engine and water heat it receives all of the time. They changed it out and I went on my way.
    Bill
  • The tank is probably cracked at the threads. Buy a new tank
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
