otrfun's avatar
otrfun
Explorer II
Dec 28, 2016
Leaking Lippert Axle Seals
I seem to remember reading a post or two about the seals on some Lippert axles being problematic. Searched but couldn't find anything.
FWIW, the brakes on our 5th wheel toy hauler (with 7k Lippert axles and 12x2 Axletek brakes) have been less than stellar since we took delivery. Took our TH to the dealer a few months ago and they said the brakes were functioning properly. With our warranty ending in a few months figured I'd pull the drums just to play it safe. Glad I did. All four axle seals had varying amounts of grease leaking around them. One was leaking particularly bad with a thick layer of grease all over the brake shoes.
Seems strange that all four were leaking. Did Lippert have a large batch of bad seals? Or, did Lippert use the EZ/Super lube zerk fittings during assembly and force-in too much grease. I never grease these zerk fittings just because of the risk of blowing grease past the seals. IMO, annual repacks should be sufficient.
Fortunately, our dealer was willing to submit a warranty request to Lippert based on pictures I took of the brakes, seals, and drums.
Still thinking seriously about doing a disc brake conversion. At least with disc brakes the axle seal is clearly visible so any leaks can be caught early :)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
