ewhitefo
Aug 06, 2011Explorer
I found some online but am waiting to see if they are backordered, do you still have the extras? Would you want to sell one or two? My pump setup looks similar to the pic accept I have a couple solenoid valves to control flow direction so my motor turns one direction and the valves control flow. Probably saves on the seal between the pump and motor since it only ever turns one way but it also has two more parts to fail, the two valves. It all seems to work real well accept for the leak, I talked to lippert and a new setup if I shop around runs about 350.00-400.00, lippert its over 1000.00, not sure why so much more. He told me to use the permatex but I, like you want to be able to get it apart again. Another question, did you have to bleed your system much after you put it back together?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
