oldmattb's avatar
oldmattb
Leaking Rear Hub on DP
My hub started leaking recently. This will be my first experience with this.
First, I am assuming that this is likely just a leaking cover plate, and not a symptom of something serious. I see no cracks nor damage, and there appeared to be a piece of thin gasket material sticking out from between the plate and wheel. Second, I assume the lube is the same that is in the differential, since there are no caps or fittings to install lube at the wheel.
Third, I am thinking the repair would be to drain the diff, remove the plate, clean up the surfaces, install gasket and reinstall.
Am I on track? Is it necessary to drain the diff? Would blocks of a safe height under the wheels on one side keep the fluid at bay until I could to the repair? Should I use a factory gasket, or will RTV do the job?
Or am I way off?
Matt B
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
