DRM796's avatar
DRM796
Explorer II
Sep 21, 2022
Leaking Schwintek slide rail
Have a schwintek slide that leaks at the lower rail and gets the bottom side of the slide wet. I have caulked all along the rail and the mounting screws but some how water still gets thru to the bottom. Done some web searching but haven't been able to find any definitive fixes. Any ideas?
Thanks
    Thanks
    With the slide open and unit level put a level on the rail. Does it have a slight slope to the outside end of the slide? It should so that any water flows to the outside, not through the gasket at the sidewall opening. The way the gasket is designed a hard wind driven rain blowing towards the camper is coming in regardless, but that should be a minimal amount of water.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
