myredracer's avatar
myredracer
Explorer II
Oct 19, 2017
Leaking slide from towing in heavy rain?
The background: Got home last night from a late season camping trip in southern WA (just the dog & me so no copilot). Sunny summer-like weather on Monday! Started out in light rain and no wind that should have been a routine 4-5 hour trip home. Turned into an epic 10 hour trip due to a fall storm with high winds and pounding rain. Knew about the weather forecast but no concern. All was well until almost to the ferry I had planned to take from the Olympic Peninsula to Whidbey Island (about an hour from the border), there was a sign on the road saying the ferry was shut down. Had to double back southward and take another ferry over to the north side of Seattle area, then got caught up in HEAVY commuter traffic out of Seattle. So, many hours of towing in heavy rain... :( :(
The issue: Went into the TT at home last night to find water on the floor from under a foot or two length of the carpeted slide floor and running across the floor. Not much but enough to be a concern, as any water intrusion is. Def. not from an inside spill. (Wheel well is under the slide.) Pushed a paper towel a bit under the slide floor and it got wet. Definitely not from the vertical seals or seal along the top.
Can a leak be from water thrown up from the tires into the wheel well area and get inside? Looking under the slide this morning, there looks to be a seal immediately above outer edge of the outrigger and under the slide floor and it *seems* okay. Could the slide maybe need adjustment or is the water simply a consequence of towing for so long in heavy rain? Don't recall ever reading about something like this.
