dougrainer
Aug 07, 2016Nomad
rv2go wrote:
I damaged mine when the shore power went off. Too big of a load on the inverter and it failed to trip off. Cost me several hundred dollars.
I now leave mine off when connected to shore power. The little inconvenience it may cause is cheaper than repairs or replacement.
1. Your Inverter is not installed to specifications
2. The "Load" if too much should not have harmed anything as the Inverter has Circuit Breakers that will trip from overload
3. The OUTPUT loads should be within the 30 amp power of the Inverter. See item 1. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
