ledcompExplorerMay 16, 2015LED DimmerI wanted to stabilize my LED lighting circuit voltage using a buck/boost converter. When the LED's are dimmed you can see alot of fluctuation from battery voltage change like when the water pump cycle...Show More
MEXICOWANDERERExplorerMay 17, 2015I use the $2.95 (8) amp dimmer as found on BuyInCoins.comA 470uf 25-volt electrolytic capacitor inline BEFORE the dimmer helps.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
Related ContentDimmer for led lightsHow to adjust LED headlights?Installing a dimmer switchDimmer wall switch for interior LED lights?Dimmer for (+) Side
