I wanted to stabilize my LED lighting circuit voltage using a buck/boost converter. When the LED's are dimmed you can see alot of fluctuation from battery voltage change like when the water pump cycle...
Be SURE that adding a cap does NOT affect the voltage status of the converter. I forgot the Fred Flintstone grade ferroresonant converters did not die off when the asteroid hit.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
