ledcompExplorerMay 16, 2015LED DimmerI wanted to stabilize my LED lighting circuit voltage using a buck/boost converter. When the LED's are dimmed you can see alot of fluctuation from battery voltage change like when the water pump cycle...Show More
GordonThreeExplorerMay 17, 2015How well do the LED perform at 9 volts? A straight buck converter would be easier to find than a boost-buck, forward or sepic converter. Are you dimming all the leds in the rig, or just a strip of them, or a single fixture?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
Related ContentDimmer for led lightsHow to adjust LED headlights?Installing a dimmer switchDimmer wall switch for interior LED lights?Dimmer for (+) Side
