ledcomp
May 16, 2015Explorer
LED Dimmer
I wanted to stabilize my LED lighting circuit voltage using a buck/boost converter. When the LED's are dimmed you can see alot of fluctuation from battery voltage change like when the water pump cycle...
GordonThree wrote:
How well do the LED perform at 9 volts? A straight buck converter would be easier to find than a boost-buck, forward or sepic converter.
Are you dimming all the leds in the rig, or just a strip of them, or a single fixture?
