ledcompExplorerMay 16, 2015LED DimmerI wanted to stabilize my LED lighting circuit voltage using a buck/boost converter. When the LED's are dimmed you can see alot of fluctuation from battery voltage change like when the water pump cycle...Show More
MEXICOWANDERERExplorerMay 18, 2015Hmmm. A converter that drives a boost that in turns drives a bucker, that in turn drives another power supply.HEY RUBE !!!
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
Related ContentDimmer for led lightsHow to adjust LED headlights?Installing a dimmer switchDimmer wall switch for interior LED lights?Dimmer for (+) Side
