I decided that I would try and change the tail lights on my Tradewinds over to LEDs and see if they are any brighter. I pulled the old bulb,got the number, Sylvania 3457 and headed for the rv store. ...
Replacing only the tail lamp with an LED will most always disappoint. You should replace the entire fixture with an LED fixture.
Your original lamp was 402 lumen and 38 lumen. For an LED to be brighter it has to beat these measurements plus be properly designed to work in a reflector type fixture.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
