Bigdog
Oct 29, 2014Explorer
LED tail lights.
I decided that I would try and change the tail lights on my Tradewinds over to LEDs and see if they are any brighter. I pulled the old bulb,got the number, Sylvania 3457 and headed for the rv store. ...
beemerphile1 wrote:
Replacing only the tail lamp with an LED will most always disappoint. You should replace the entire fixture with an LED fixture.
Your original lamp was 402 lumen and 38 lumen. For an LED to be brighter it has to beat these measurements plus be properly designed to work in a reflector type fixture.
