Bigdog
Oct 29, 2014Explorer
LED tail lights.
I decided that I would try and change the tail lights on my Tradewinds over to LEDs and see if they are any brighter. I pulled the old bulb,got the number, Sylvania 3457 and headed for the rv store. ...
PatrickA51 wrote:j-d wrote:
Beemerphile nailed it. Replace the assemblies or don't bother.
I got this type here They look like this
except I got the triples with backup lights. $50 each for the ones pictured and $60 each for the triples.
And they are AWESOME!!!Posted By wrote:
beemerphile1 wrote:
Replacing only the tail lamp with an LED will most always disappoint. You should replace the entire fixture with an LED fixture.
Your original lamp was 402 lumen and 38 lumen. For an LED to be brighter it has to beat these measurements plus be properly designed to work in a reflector type fixture.
I also agree with this! I tried the bulb replacement route and was very very disappointed. Go for a LED designed fixture.
X3
I was going to do the same to my RV and decided on replacing the whole assembly.
