profdant139
May 27, 2016Explorer II
Let 12V battery drop to 50 pct, or top it off daily?
(I apologize in advance if this topic has already been asked and answered -- my search of the archives came up empty -- possibly using the wrong keywords?)
Anyway, here is the question: is it at all beneficial to discharge a deep cycle 12 volt battery to around 12.1 volts (50 pct state of charge) repeatedly, or is it better to keep it essentially topped off? (These are group 31s, allegedly "marine" batteries, rated at 110 amp hours.) I am, of course, trying to extend the useful life of the batteries. I am guessing it is better to top off than to let it run down even a little, but that is just a guess.
The reason I ask is that in the old days, before I got a 120 watt portable solar panel, I would let the voltage go down to 12.2 or so after three days of use, and then swap out the used battery for my fresh spare.
But now with the solar panel, my battery almost never drops below 12.4 -- the solar panel tops it off every day, and one night's usage never causes it to fall below 12.5 or 12.4. (We are very careful when it comes to energy usage -- LED lights, minimal furnace use, etc.)
If it is somehow beneficial to let the battery run down a little more, I would skip a day with the solar panel, now and then. Otherwise, I will continue to top off every day.
I should also add that when we are not camping, the batteries are hooked up to a float charger.
Thanks in advance for your advice!
