enblethen
Jul 22, 2022Nomad
I would suggest changing the fluid. It is easy to do. Biggest issue is to insure you drain fluid fully. Will need to jack up each side one at a time to get old fluid out of hubs. You must do the reverse when filling to get new fluid into each hub area. Final fill level would be done after accomplishing alternating.
Inspect old fluid for metal debris.
OP: do you have rear drums or disc brakes? My discs run hotter than drums!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
