RLS7201
Jul 23, 2022Explorer II
Huntindog wrote:
It is not just full floating rearends that use the differential oil for the bearings. Semi floaters do as well. In fact I have never heard of a conventional rearend that uses grease for them...FWIW, I have totally rebuilt axles incuding setting up new Ring and Pinion gears.
Now your showing your age.........About 1964 the auto/light truck manufactures switched to axle bearings that lubed with def. grease. Before that the press on axle bearings has grease in them with seals on both sides. MOPAR used tapered axle bearings pack with grease and seals on both sides of the bearings. The right side axle bearing had an adjustment to set the end play.
Richard
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
