enblethen
Jul 25, 2022Nomad
No, the sprocket is the drive. Most have a flange welded to the axle shaft. Mine has a sprocket that engages to the hub assembly.
Mine are like this
axle
If the rig is not tilted to each side, there may not be sufficient oil in the hub assemblies. Must tilt each direction then top off differential fluid. Took about an extra quart.
Mine are like this
axle
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
