bka0721
Jul 02, 2013Explorer II
HiTech wrote:Not necessarily. If you were to stack the cable into a coil (welding cable), it would not fatigue as fast or at least in our life time for the amount of flexing that would occur. This could operate as a spring would, but it would require a bit larger pipe.
Robotic or welding cable would probably work well. It all depends how tight a radius the bends end up being when retracted I bet.
Jim
It has been mentioned about the cable fatiguing by the up and down movement, but my concern would be the down time, meaning the long periods before the cable insulation is exercise. Rubber/derivatives excise oils when heated/moved and harden and dry out when not. That is where I would be concerned is the lack of use and overheating the cable due to improper sizing.
b
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
