Rbertalotto
Jul 01, 2013Explorer
Let's Try This Again.Why wdn't I buy this Solar Kit for $264
I did some calculations on my needs to run my water pump a few times a day and power my laptop for two hours total and a couple LED lights for a few hours and it seems 120 Watts might be sufficient to keep my battery up on sunny days. My Honda EU2000i will do duty on sunless days. The price od solar per watts seems to have plumited just in the last few months. These new system prices from Solar Boulevard were just posted on June 13. I'm seeing 120watt systems from $250 to well over $600.
This one from from Solar Boulevard is $288 and from what I can find out on the internet they seem to be a reputable concern.
http://www.solarblvd.com/p2748/12-Volt-120-Watt-Solar-Panel-Kit-with-FREE-SHIPPING/product_info.html
But it is also available on Ebay from same vendor (Solar Boulevard) for a few $$ less....$264 No tax/free shipping
http://www.ebay.com/itm/Complete-Kit-120-W-Watt-120W-120Watts-Photovoltaic-PV-Solar-Panel-12V-RV-Boat-/271209960880?pt=LH_DefaultDomain_0&hash=item3f255f95b0
Brand New
Solar Cynergy 120 Watt 12 Volt Monocrystalline
Solar Panel Complete Kit.
You will receive:
1 pcs: 120 Watt 12 Volt Solar Panel
1 pcs: Phocos CML-20, 20 Amp 12V PWM Charge Controller
1 pcs: Phocos CMM Volts/Amp Display For Charge Controller
1 pcs: 40 FT 10 Gauge PV Cable With MC4 Connectors
1 pcs: Z Bracket (4 Pack)
PV-SC120J12
Solar Cynergy photovoltaic modules are designed for commercial and domestic applications and suitable for both grid-tied and off grid systems. Solar Cynergy offers both high performance and reliability. The silicon solar cells, held by heavy duty anodized aluminum frames, are laminated with TPT & EVA for longer working life and high efficiency output. An ideal power supply for boats, traffic signs, lights, pumps, vehicles, RVs, homes, camping and caravans.
Model Name: PV-SC120J12
Number of Cells: 36 cells in series (4 x 9)
Max Power: 120Wp
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 7.50
aximum Power Voltage (Vmp): 17.0
Maximum Power Current (Imp): 7.00
ensions (inches): 53.12 x 26.50 x 1.25
Weight: 27 pounds
Back of panel includes a juntion Box with MC4 Connector.
Warranty: For panels that range from 80w to 200w, an output power of more than 90% of the minimum peak power within 10 years and more than 80% in 20 years is guaranteed.
Max Module Current: 20 Amps
Max Load Current: 20 Amps
System Voltage: 12/24
Self Power Consumption: <4mA
Dimensions: 80 x 100 x 32 mm
Type Of Protection: IP22
Battery State-of-Charge display with 3 LEDs
Acoustic load disconnect pre-warning
PWM-regulation (series type)
Boost, Equalize and Float charging, also for VRLA
Automatic 12/24 Volt detection
Integrated temperature compensation
Large terminals (up to 16mmwire size)
SOC and voltage controlled LVD
Fully electronically protected
Information on the Phocos CMM:
Remote Display for Phocos CA, CML and CMLNL
Measuring and display panel current, load current and battery voltage.
Clear, readable 3-digit LCD Display
3-position switch to select which value to be displayed
3LEDs to show which value is displayed by LCD
Prepared for DIN rail and wall mounting
Any comments or suggestions are welcome
Brand New
You will receive:
PV-SC120J12
Max Power: 120Wp
Weight: 27 pounds
