Horizon170
Oct 09, 2014Explorer
alfredmay wrote:
When I was researching this topic years ago what I found was a statement by (I believe) Norcold in their owners manual that the allowed tolerance was up to 3 degrees side to side and 6 degrees front to back. I purchased small levels that were graduated in degrees and placed them on the refer. A quick check told me if I was OK to run the refer.
The item is Lev O Gage II and is found in RV stores.
http://www.suncompany.net/productDetail.php?stockNumber=306-R
I agree, Below is a copy and paste formula that I used when I had a 3 way fridge.
"If you use a 9" level on your counter top or un-carpeted floor,
with one end touching surface, by raising the low end of the level until the bubble is centered between the lines the raised end should be less than 1\2" above the countertop. Actually at 9" length 15/32"= 3 degrees. I think most boxes allow up to 3 degrees side to side and 6 front to rear ( of box ) Hope this helps"
Marvin
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
