base1957
Nov 03, 2017Explorer
Doug
I believe I do know what it looks like. I just can't seem to get this leveling issue solved. The fuses are good I the box. Now, when I push the auto level button on the 610 system. Two Jack's will come down ,one front and one rear on diagonal sides. They will extend, bit them pump will not stop unless I turn it off. After turning it off and then back on I can get the other two Jack's to extend. Sometimes one at a time....the biggest diagnosis issue. Having is trying to get the same result s when I try the system.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
