base1957
Nov 03, 2017Explorer
Me..wizard...it's erratic as well. For instance if I push the rear Jack's to extend maybe one will....then I turn it off and back on and another will.come down...had to eepeat this individually for respective Jack's. My biggest issue is the inconsistent behavior of the system.
I was told.by Winnebago that perhaps the shuttle eelay or pressure switch near the rear hydraulic pump motor is a possibility.
It seems to me that if the control box was bad then it would never work. I suppose the push control pad might be a possibility.....the reason I can't pin it down it I cannot get consistent results.
Thanks
Thanks
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
