Teleman
Nov 08, 2021Explorer
otrfun wrote:Teleman wrote:A BMS is not designed to function as a charger. It is designed as final line of defense to protect the battery.
I ordered a 200AH LifePo battery to replace my two 100AH lead acid batteries and also a compatabile converter which takes care of charging the battery with shore or generator power but what about charging the battery with the alternator? Does the battery's BMS take care of everything and therefore no need to change or upgrade the alternator? Sorry if this is a dumb question!
If you're counting on the wiring to/from the alternator to limit current between your alternator and batteries, you're going to have to choose the proper gauge wire or cable. Too big (physically), may allow excessive current (potentially overloading both the alternator and/or battery). Too little current will result in excessive charge times. There's no magical chart that's going to give you a precise answer. If you've priced copper wire lately, a trial and error approach could get very expensive. Also, if you change size/type of batteries in the future, you'll need to current match the wiring again.
That's one of the upsides to using a dc to dc charger. It will limit current to a precise amount. Sized properly, you're never in danger of overloading your alternator, plus it will properly charge your lifepo4 by precisely controlling the voltage applied to the battery. IMO $200-$300 for a dc to dc charger is a good insurance to protect both your motorhome and battery.
As for using a fuse as an alternator/battery current limiting device, that's not recommended. Fuses are very inexact devices. Some fuses can allow up to twice their current rating before they open. Fuses are primarily designed to protect in the event of a direct short.
What should I be looking for in a DC to DC charger given a 124A alternator and a 200AH lithium battery? I suppose it's possible I may add a second battery in the future as my motorhomes has space for two.
