Teleman
Nov 08, 2021Explorer
pianotuna wrote:
Teleman,
You Li batteries will not "like" life under the hood.
DC to DC are not happy about under the hood either.
I have a similar alternator. I deliberately chose a 20 amp DC to DC unit from Renogy.
If I were buying again, I might go to 40 amps, but only because it has a "link" that when removed puts it back down to 20 amps.
https://www.renogy.com/12v-20a-dc-to-dc-on-board-battery-charger/
Victron makes a similar more expense (but probably more reliable) unit.
Can you explain why? Bear in mind under the hood in a Class A is isolated from the engine. The only problem I see is moisture when it's raining.
