Gjac
May 13, 2013Explorer III
Mena I was thinking of a small solar system before 2 more batteries if usage increased just to top of the batteries after running genset. BFL do you equalize after every trip to fully charge? Wouldn't the Magnatec 950 float charge do the same thing and be easier on the plates? I only have 6 in clearance above the batteries with no slide out so I can just fit the floating needle hydrometer from WM in there so most of the time I use the HF volt meter instead. My 950 floats at 13.4 v and I only leave it on 3 days after B&D says Full.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
