taz100's avatar
taz100
Limited power in 2004 38 ft monoco sahara Safari
I screwed up, had shore power hook up with air conditioners running and started Generator. About 2 min later lost almost all power in motor home. Have power coming into main breaker from shore or generator, and leaveing all smaller breakers. Such as air conditioners ect. But they don't work. Have no power on contoll panel to set air conditner temps ect. Most lights don't work 120 volt or 12 volt. Power on main breaker is 120 or 220 as it should be. a few plug in work. A couple of lights work in kitchen. Tvs work. Power Awning, most lights, air conditioners don't. Micorwave and frig work.
Since power is on at main breakers in motor home does that mean transfer switch is ok.
House Batteries are up. Tried shore line alone, gen running alone, and just house batteries alone. No difference.
I don't understand how ac and dc seem to both be down.
Motorhone itself runs great. Don't mind taking it to shop but a very long waiting list.
Any input would be great.
  • Our 2000 Monaco has a rocker switch on the dash to start the generator without going outside. This means that it is OK to start the generator without disconnecting from the electric. Doesn't yours have the same? Our converter automatically switches to the generator if running and then back to the electric when the generator is shut off. Maybe your auto portion of the converter isn't working correctly.
  • Thanks to all who posted.
    Its Fixed
    I turned everything off, all breakers including breaker on generator, invertor and ect. Turned battery bank off.
    Slowly turned everything back on. Don't forget breaker on generator must be turned back on.
    Everything worked except thermostat in hall which controls air conditioner and heat pump. I had no power to it. From there I tracked problem down to a 3 amp blown fuse in back air conditioner on roof. Cost me .75 cents for fuse.
    I will be more careful from now on about turning generator on while shore line pluged in.
    Thanks again to all who posted.
  • unplug shore power
    turn off ALL breakers, all the way off, including the TWO breakers on the SIDE of your Generator
    also check your INverter charger/converter devices
    for circuit breakers and fuses mount on them
    leave shore unplugged
    try the generator first, check all circuits for power
    yes you could have damaged the transfer switch, it might have burnt stuck contacts and not switching correctly
    save that for last you will need ALL power off and disconnected before opening that and sticking your fingers in there
    after you test the Generator, turn it off and then plug in shore power and test again
    BTW this is why you should unplug shore power first
    I'll say it again
    an RV transfer switch is NOT the same as an Emergency power failure switch
    generator power switch
    ONE important fact is missing
    the UTILITY COMPANY POWER FAILURE
    in power fail situation, utility power has failed. before the generator starts
    it is already dead no incoming power
    loads have already been turned off, by the power failure
    even if it is only seconds in the switch
    NO hot loads are switched, no arcing of utility power on the contacts
    no sticky contact causing a cross connection
    ALWAYS ..ALWAYS..turn off loads, unplug shore power before starting the generator
    the few minutes of lazy butt time saved are NOT worth the RISk
  • Check the reset for your converter and or inverter one of them may have tripped.
    Also on my RV there are two circuit breakers mounted near the slideout controls, one of these also provides protection to the converter. The circuit breaker is the automotive type small black plastic about an 1 1/2 long with a micro switch to reset and two wire connections.
    And one or more of your GFCI receptacles may have tripped and is affecting the entire circuit.
  • have you checked the two smallish fuses on the inverter? They pop out and needed to be pushed in to reset them.
  • Read your post twice but I can't quite make sense out of it.
    I start my generator all the time while plugged in with No problems.
    I am going to read your post again. I am an electrical troubleshooter and would like to help.
    My ACs have a two minute delay to kick in.
    After reading again it appears you have lost 12 volts. Did your battery disconnect get activated?
    Not sure if your thermostats are powered off your 120vac or your 12v supply.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
