Curly2001's avatar
Curly2001
Explorer II
Sep 05, 2020
Lippert electric slide out dead
Have been traveling for over a week and got to our new campsite and found no power to the slide out. Checked fuses and the wiring that I could see and no power. Had to manually crank out the slide. Not sure what to check or if there are other fuses to check in that system. Any ideas would be appreciated. Does anyone know if Lippert uses any circuit breakers that need to be reset? I see an electrical box under the slide but it has been raining and have not had a chance to open it.
Thanks,
Curly
  • You should have an auto resetting breaker similar to this, not far from your batteries, maybe on wall inside basement. Some may be manual reset?
    Jerry
Having RV issues? Connect with others who have been in your shoes.24,243 PostsLatest Activity: May 11, 2025
