dougrainer
Jun 10, 2014Nomad
On the side of the frame, do you have a gold colored "bell" looking part that stops against the Hole if the frame? If so, you have a screw drive system and when you hear that clicking, it means the Screw drive and clutch has failed. If you have this type, if you turn that hex head, it will release the tension and the system should operate. Another way to get it to free up is to constantly hit extend and retract and sometimes it will jar it enough to free it up, but you still need to replace the screwdrive/motor system as it is bad. Copy and paste this link to see what that "bell looks like and confirm this is what you have. Doug
http://store.lci1.com/stop-can-regular-p379.aspx
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
