stevemorris's avatar
stevemorris
Lithium Battery Upgrade
i need a new battery for our 26ft tt, the old lead/acid rv/marine battery is virtually dead after 10 years of service.
is it worthwhile to upgrade to a 100 Ah li battery and the necessary new charger?
we do boondock occasionally and probably would do more with a better battery capacity. the old lead/acid battery was rarely adequete for more than one night boondocking running the usual lights, fridge and water heater controls.
  • In addition to what was said above, you really only get about 50% of the rated amp hours out of a lead acid battery - and if drained too low, it's toast. With LiFePO4, nearly 100% of the rated amp hours are available and they have 1,000s of charge cycles in them over their lifetime. One caution: with a travel trailer and the battery stored on the tongue, you'll need to be careful about the battery charging in very cold temps. To get around this, you can buy a heated battery, put a thermostatically controlled heating pad around it, remove the battery during the winter, or move it inside the trailer (they don't need to be vented). We have four 100 AH Battle Born batteries in our fifth wheel to operate the residential refrigerator (via an inverter) while traveling or during power outages and they are great. We love them.
    Rob
  • Short answer. YES. Bonus, just 23# each vs. SLA @ 65#, double the useable capacity, and can be installed almost ANYWHERE.
    You can get a battery with Bluetooth monitoring so it’s even easier to track usage.
    I replaced my battery and bought a $20 plug in charger to top off and equalize my battery occasionally. Not paying for a converter charger upgrade, parts alone were about $270.
    The stock converter charger, even if non Lithium capable, will charge the battery to about 90% on the average. So far, mine seems to be keeping them (bought two batteries) at 100%.
    You can also use solar to top them off if you get into that.
    The ONLY downside to consider is LiFePO4 batteries can be damaged if charging is attempted below freezing. So if you want to leave it mounted year round in cold climates, you’ll need one with low temperature protection in its Battery Management System (BMS), or take other actions. My 2nd battery’s manual (yes, it has one) states to not store it under 14*F. My 2nd battery was bought cheaply and doesn’t have all the same BMS as my 1st one.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
