pianotuna wrote:
01tundra wrote:
pianotuna wrote:
Freep wrote:
pianotuna wrote:
Unfortunately I need -40. There is at least one LI chemistry that can do that--but nothing in a large format jar. Lithium titanate
Do you really need -40? Do you have no water in your rig, only ice?
-40 will kill Li batteries. I've boondocked at -37 c (-34 f). That temperature will also kill Li.
I've since found a battery chemistry called SiO2 which shares many of the attributes of Li. The differences that I'm aware of at weight (greater than a similar capacity lead acid) and the ability to be used and charged at -40. Some of the shared items are no sulphation, and zero maintenance. That means no more needing to get to 100% state of charge.
The SiO2 is about 1/2 the price of Li. It can "do" 900 amps for 5 seconds from a 100 amp jar, which I think is better than Li.
Cycle life is 2800 if you don't go below 50% soc, and 1500 if you go down to 20% soc.
Best of all, the SiO2 are sold in Canada. $600 ($450 usd) for 100 amp-hours. This is a competitive price with AGM.
Mount the batteries inside the trailer?
That won't help save LI when the RV is in storage.
if its in storage your not using the batteries so no issues at all, the temps are only for discharging or charging. just make sure there disconected and your good to go
Steve
