wa8yxm
Jun 16, 2019Explorer III
42 amp hour at 12 volts is what 500 watt hours Mex you said 50 VA at 12 volt (At 12 volt DC VA = Watts by the way PF not a factor at DC). So you'd have around 10 hours run time assuming 12 volt battery. Or less. Not sure if you can run LI's to zero or not.
Two of 'em and swich when you neat the head at 1AM might.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
