BFL13
Mar 09, 2018Explorer II
You want to run your Ds at 50lbs the same as the Cs is the issue. My understanding is that you can do that with LT Ds but not with ST Ds.
I may have this wrong, but from reading various tire posts, STs should be fully inflated, but you can do the weight/PSI table thing ok with LTs.
EG I have LT Es on my wheels that came with Ds but limit the LT Es to 65, even though they can go to 80, but the wheels might only do 65 as for Ds (have not checked the actual wheel specs in case they can do more than 65. Don't need more than 65)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
