lawrosa
Mar 09, 2018Explorer
BFL13 wrote:
You want to run your Ds at 50lbs the same as the Cs is the issue. My understanding is that you can do that with LT Ds but not with ST Ds.
I may have this wrong, but from reading various tire posts, STs should be fully inflated, but you can do the weight/PSI table thing ok with LTs.
EG I have LT Es on my wheels that came with Ds but limit the LT Es to 65, even though they can go to 80, but the wheels might only do 65 as for Ds (have not checked the actual wheel specs in case they can do more than 65. Don't need more than 65)
Thanks for that.. Hmmm
The inflation tables are for st tires.
So @ 50 psi they are 1760 just like my C's.
x 4 thats 7040. If I loaded the trailer to max 7000 lbs. ( Will never happen I can tell you but if I did whats the impications of running 50 psi?
Alright alright, somehow in my head I feel I will do something drastic if I dont inflate to 65 psi is why I asked the question..
To meet someway towards a middle point I stated I would be willing to do 55 psi.
I have to admit when I did my trip to florida and back my 81 mph jaxxons saw 75 mph most of the trip down rt 95 b lining it there. I checked pressures every morning before heading out. Maintained 50 psi diligently.
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
What other tires are recommended here? I read something on maxis tires?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
