Fisherman
Aug 26, 2020Explorer
What Rhett25 said, they are too cheap to install an 8 or 10 ga. ground wire (negative) from the battery location to the distribution panel. Found the same on mine. Battery is grounded at the front of the trailer and they run another wire from the frame up through the floor to the distribution panel. Save 15 feet of wire, yet need to install 2 ground points on the frame that will corrode quickly.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
