CA_Traveler
Aug 27, 2020Explorer III
OP, The negative distribution uses the frame with negative wires connected at various points in the RV. The panel fuses and distributes the positive connection only. There may be a limited negative ground for panel lights, etc. Hence there is no place to install the shunt on the negative lead and near the battery is the best location.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
