D_E_Bishop
Mar 05, 2014Explorer
Location of "YOUR" LP hose connection, SURVEY CONCLUDED
This is an informal survey to determine the location of extend-a-stay and external LP appliance connections.
Where is your tap, quick release or screw on, is it before the regulator or after the regulator? Was yours installed at the factory, at an LP dealers shop or a DIY project?
Mine is a std., cylinder thread connector installed between the tank shut off valve and before the regulator by Fleetwood.
I looked at the Sturgisafe, Sturgi-stay fitting and it is shown installed between the valve and the regulator. Camco is the same and says in the catalog I have "for installation between the valve and the regulator". Both of these are for either using an external tank for extended use or occasional use.
So where is yours?
So where is yours?
