DougE's avatar
DougE
Longest Satisfactory Use of Easy Lube Axles?
Dexter Easy Lube Axles and those similar appear to be a great system (not to be confused with Bearing Buddies). I have always considered that hand repacking of bearings was a good way to introduce dirt into the system regardless of how much care is used. Consequently I like bearing packers to push out the old grease without soaking the bearings in cleaner and drying before hand packing. Easy lube axles, if greased according to instruction appear to be the best system. Pneumatic grease guns (not recommended by Dexter) over pressure the system and sometimes result in the seal failure reported by some. Who among you had the most service life using the Easy Lube Axles? Please share your experience to validate whether this is an excellent system.
