obscenic's avatar
obscenic
Looking for a power centre compatible with 240v breakers
Greetings comrades.
I'm in the midst of an electrical upgrade project on a class B motorhome. It's a 1983 and currently has just 15amp u-ground service. One breaker, which splits to all outlets, appliances and to a 12v converter.
I'm a fulltimer, and I'm switching to electric heat from propane (convenience factor). Due to my climate, this leaves me needing a 240v heater. I've got 30amp, 240v service (L1, L2, N, G) so I can run my 240v heater as well as my 120v appliances. Since the converter is original (1983) and only has a single stage charger (and I have a brand new high quality AGM battery bank), I think it's probably time to put in a power centre.
What I'm struggling with is finding a power centre that meets the following criteria:
1. Must have 240v capability (ie, I can put a 2 pole breaker into it with one pole on each leg)
2. Must have a multi stage changer converter.
3. Doesn't need to be high capacity, I'll probably put a 30amp main breaker in instead of a 50.
4. The converter doesn't need to be high capacity - all of my lighting is LED and the only other things on 12v are a vent fan and water pump.
5. I don't have a generator so I don't need a xfer switch.
6. Needs to be as compact as possible as it will end up located underneath a dinette bench seat, where the breaker and converter presently live.
I'm looking at http://www.parallaxpower.com/power-centers-5300-series but unsure if it will allow a 2 pole breaker and it's unclear whether or not it has a 4 stage charger.
Any other suggestions are welcome!
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
