MN_Ben's avatar
MN_Ben
Looking for help with my faulty tail light
I have a 2005 Lance truck camper. I use the proprietary plug that Lance requires. The connections are correct and I used a test light to make sure the truck side plug works correctly. My 2005 Lance 981 Max looks to have LED's that make up the tail lights (3 wires coming from out of the tail light). I have been having trouble with the passenger one. It does not always come on.
Today when I looked at it , the LEDs were very dim, and not all of them light up. The longer I had the light on, the brighter the LEDs became, but again, not all lit up. At first there were 8 lit up, then 10. I have no idea how to correct his.
Can someone help?
  • The brand was Glo-Brite. Peterson had an exact fit. The wire harness plug even went right in. Ten minutes of time and $32 later and I had both tail lights replaced.
    Thanks for your replies.
  • ScottG wrote:
    Very common with that particular light. The lamp assembly itself is failing.
    Only choice is to replace it.
    X2, looks like it is failing.
  • Very common with that particular light. The lamp assembly itself is failing.
