mchero's avatar
mchero
Looking for replacement pancake air tank
Last couple of trips I have noticed that the compressor for my air horns cycling. The tank is mounted on the firewall on the drivers side. It appears to be a 2 gallon tank. I believe that since the tank is mounted on the firewall I have no drain on the tank. I believe the water sits on the bottom of the tank rusting away.
Not sure who Fleetwood purchased their air tanks from back in the 90's.
I'll try & get some pictures posted.
Thanks.
  • j-d's avatar
    j-d
    Explorer II
    I was at Harbor Freight the other day and they had a 3-gallon pancake tank for $39.95. Had a 120VAC compressor on top, but the tank might be cheaper as a part than air horn parts.
  • The bottom half of the air tank is rusted and leaking.
    Don't need any soap to tell me their is a leak on this 20+ year old air tank.
    Thanks for the reply
  • Have you checked for bubbles to verify the tank is defective? Could also be fittings or bad hose.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
