CT_WANDERER's avatar
CT_WANDERER
Looking To Add Solar Down The Road
I am planning on adding solar down the road from now. Would like to see if I am on the right tract. I want to install three Kyocera 140 watt panels flat on top. Wired in parallel to a BlueSky 2000E, then to the my battery bank of four GC2's.I know the BlueSjy will chop any amps over 25 amp. My concern is the run from the 2000E to the batteries will be 25' I Plan on using 2AWG wire for the run to help over come the distance. My goal is to be able to run the gen in the morning for two hours or less. Then let the solar take over for the rest of the day. With maybe a little boost at night if needed. Will this set up work or is the 2AWG run going to do me in? I know I should keep it as short as possible. But this layout I plan would make it the easiest way to get things though the MH and monitor the system. Right now I see about a 60-85 amp draw my Trimetric from 6:00 PM to about 9:00 AM.
I mean it would be great if I could make without the gen. So far I am not one to conserve energy, but maybe I should if I go this way. Thanks for any input Gary
After reading this over, right now I am not sure of my amp draw reading. I will have to make another test run the next time I go out with the MH to dry camp.
Having RV issues? Connect with others who have been in your shoes.24,332 PostsLatest Activity: Nov 06, 2025
