CA_Traveler
Nov 13, 2019Explorer III
Typically inverters don't pass 12V, they use 12V as input. Charger/inverter units use the same 12V wires to charge the batteries.
"I have checked my battery cut off switch and it is open and also providing 13.5v on both sides, prior to the circuit breaker."
Open means off and this is your problem. Turn the switch on or closed. Voltage on both sides does not mean the switch is closed.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
