BFL13
Nov 13, 2019Explorer II
10David43 wrote:
I have eliminated my converter and my inverter. Neither can effect my 12v input to the panel. The inverter has no 12v output it only takes 12v in to make 120v and my converter 12v wires directly into the panel were 12v comes from the battery. Per my good meter, the circuit breaker is closed allowing power to flow. So somehow and somewhere between there and my panel, I have an issue. Unfortunately it is going to require pulling the paneling off of the bottom of the trailer to trace the wires. Thank you for giving input, I do appreciate it.
You don't need to get at those wires.
You are just confused about how your rig operates when on and when off shore power.
Yes voltmeters read high when their batteries are near dead. New battery should fix that.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
