krobbe
Nov 01, 2015Explorer
If no breaker or GFCI is tripped, start looking for a burned or broken wire or receptacle. Space heaters use alot of current and can burn up an outlet with a loosely connected wire. Start with the outlet where the heater was plugged into that is closest to the distribution panel. These outlets are daisy chained together and the closest one without power to the circuit panel will be the culprit. If no outlets are working, then look in the circuit panel for a broken wire or a bad breaker. I've seen all of these scenarios.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
