wa8yxm
Nov 01, 2015Explorer III
I Love the folks who automatically say GFCI.. odds are that's not the problem
If you have an inverter than you have TWO breaker panels. One is your main power distribution center.. The other may be a 2nd panel located somewhere else or it may be breakers ON the inverter itself.. SUSPECT #1 is said inverter breaker panel.
#2 is the connections to the inverter itself. and #3 is one of the outlets (not sure which, need not be the one you plugged into)
Also junction boxes epically if there is a slide out in the power path.
RV wiring is "Rated" (Supposedly) for Space Heaters.. but I and others have found it's not really up to the task.. I wound up installing special outlets for the Heaters.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
