lanerd
Nov 01, 2015Explorer II
lanerd wrote:
Ok, common problem. If you have an inverter, there are usually two push button type of circuit breakers on the side/end of the inverter box itself. Check and make sure one or both are not tripped.
If you don't have an inverter, forget I said anything.
Ron
Posted By: wa8yxm on 11/01/15 04:24pm
I Love the folks who automatically say GFCI.. odds are that's not the problem
If you have an inverter than you have TWO breaker panels. One is your main power distribution center.. The other may be a 2nd panel located somewhere else or it may be breakers ON the inverter itself.. SUSPECT #1 is said inverter breaker panel.
Like minds..
Ron
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
