Thorshegoes
Jul 12, 2020Explorer
Lost power to HWH Leveling Jack Control Board 200 series
Hi all, I recently took my 1995 Thor Residency to a shop and they accidentally disconnected the positive 12v lead to my HWH leveling jack Control board (200 series w manual joystick)
I need help in figuring out where to reconnect as I can't find the owner's manual or any detailed wiring schematics for my motorhome.
As you can see in the pictures above, the orphan red wire with a male spade is the positive lead wire to the control board. I determined this by testing with a multimeter for conductivity.
I suspect the wire may have been disconnected from the beige colored fuse block, but I'm hesitant to think that because I don't see any female fuse taps for the male spade to connect to. I only see two fuses with male fuse taps meant for incoming female spades.
Is this fuse block the likely place for the orphan positive wire? Is there another place I should be looking behind the dashboard? I've rumaged around a bit and couldn't locate any open female terminals for the orphan positive male spade behind the dashboard.
Is there a way to bypass and go direct to another part of the chain in the case I can't find the right place?
Thanks all.
1995 ford f53 (460) chassis.
