enblethen
Aug 18, 2016Nomad
They system needs to be checked around the transfer switch. Bad contact or loose neutral would be first check.
A loose neutral can cause an increase in amperage that can trip a circuit breaker. A/C may sounds like it is working correctly but maybe effected by a problem in the system.
It could just fine on genset as that system is not effected because the problem is in the shore power portion only.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
